G'day fg I use the ram mount mounted on the seat support and a couple of small chains to stop if vibrating also they un clip so I can lift the seat up to access the motor there's a photo of mu cab on my profile album cheers Daz
Ram post. You can change height to what you want and bring it closer or further away. I use it to mount my Surface Pro3 but there are a lot of different holders to suit what ever you want. It is bolted to the floor and as you can see it has a stainless plate to help stabilize it that is bolted to the top just before the engine cover. Engine cover can still be opened but I tend to just tilt the cab. Over corrugations any mount will be a problem with movement but this is the best I have found. It is mounted in a position that three can still sit in the front but why would you as the centre seat is really not meant to be used.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
