Is GM not the best platform for a overland build?
Zackclarke
Im new to off-roading and overlanding. I’m planning on building out a composite 8’ flatbed camper. My trips will mostly be souther California mountain fire roads and Baja “roads”. I never really see the 3/4 or 1 ton GM trucks built out, it always seems to be ford or dodge and from some of the info I have found is the concern with IFS vs a solid front axle. So my question is can the GM IFS handle those types of roads with a camper on the back with little issue? Or should i try and get a truck with a solid front axle instead?
Thank you.
SDDiver5
Ford and RAM are definitely more popular but for your specific question, it will likely be able to handle it with no problem at all as long as it's not overweight.
The solid axle vs IFS has been debated so many times, it really comes down to preference. IFS definitely has more moving parts therefore more things can fail, solid axle is more durable and easier to fix/work on. IFS will be more comfortable on pavement and washboard roads. Solid axle will have more aftermarket support since they're so simple.
I personally think solid axles look way better than IFS.
deserteagle56
Mostly because of the way GM trucks are designed. I haven't looked at new GM trucks in a few years (both GM dealers in the nearest towns have shut down) but pre 2020 not only not only did stock GM 2500 and 3500 trucks not have anywhere near the ground clearance under the middle of the truck (frame hangs much lower) that a Ford or Ram has, but there were all kinds of cables hanging down below the frame also. I remember reading a test in one of the truck magazines and they made a point of talking about the low-hanging stuff. If it were a diesel model the DEF tank was located right behind the passenger side front tire and it hung down so low it would frequently get crushed or punctured. And stock the IFS is not as strong - I attend truck pulls and in several of them I watched the front ends break on a GM pickup when all that power (nothing wrong with the Duramax!) was applied. A few years ago I came across an accident on a dirt road where a Chevy 2500 front end came apart and the truck, towing a stock trailer, crashed and a horse was killed. Similar to what happened below but in this case the top A frame failed and that corner of the truck dug into the dirt, sending it out of control.
On the other hand, the GM trucks normally drive much nicer going down the highway. I've never driven a solid front axle truck that didn't wander a bit even on a smooth highway, and they don't respond to steering inputs as accurately. IFS always drives smoother over rough roads also since what affects one front wheel doesn't affect the other front wheel.
If your driving is on good roads a GM with IFS should work just fine.
Tex68w
Beach Bum
There are multiple reasons for this, 1) IFS is more complex and limiting when it comes to lifts, it's also weaker than a straight axle especially when under a loaded down HD truck 2) GM quality (or lack thereof) is a joke 3) Design characteristics already touched upon in this thread but also to include their squared off wheel wells that aren't inviting to larger tires and 4) A general lack of interest and support in the aftermarket world for off-road specific accessories however, AEV has addressed that to some degree in recent years.
Beyond all of that I can't understand why anyone would want to outright choose a GM HD truck over a Ford or RAM unless they already owned it or if it was given to them. You'll be so much further ahead simply by going with Ford or RAM if you are setting out to build a competent off-road adventure rig on a HD platform.
Kingsize24
100% agree with everything said here. GM quality is absolute garbage. They simply do not hold up, especially if offroad.
portell
I agree with a lot of info above, On the Chevy 4500, 5500 they went back to solid axles. I am starting to see overland builds with them. I debated one over the F550, but larger aftermarket support for the Ford platform moved my selection back to the Ford.
4ROAMER1
