xcmountain80
Expo,
I ask you is there a better way? I have a Yakima Space shuttle, turbo booster, solid fuel rocket, or whatever it's called. and have the hardest time getting it secured to the roof, perhaps it's because I'm 5'9" and cannot reach across the box to tighten the infuriating double dodad U bolt like system. I thought about trying to incorporate something like what Caribou does with the pelican cases but the underside of the Yakima is round much like a canoe. I've also considered using (4) single through bolts that mount through the bars. I could reinforce the floor of the Yakima and place permanent round or square washers inside some fiberglass in order to gain load distribution support.
Thought Thought thoughts?
A
A
