I just read all the posts also and I agree GXV has been very responsive with after the sales customer support and the owners seem to be very understanding, level headed and resourceful in dealing with the problems.
But as much as I have tried to resist commenting on all the problems the owners had aside from flexible mount, I think they merit discussing.
I think most of us think about buying or building an 'expedition' camper so we can avoid the problems of using a poorly designed and constructed 'typical' RV in difficult conditions in remote places far from repair facilities.
The problems with the flexible mount are difficult to criticize without more information, but the problems the owners had with the plumbing, refrigeration, heating and auxiliary fuel tank are perfect examples of problems with a typical RV.
The use of tubing not rated for the temperature and pressure in a pressure hot water system that caused the water leak in their shower and the fact they had to cut open the interior to diagnose and locate the problem should be unacceptable. The water temperature in an engine heated system can reach over 200F, much higher than a typical home or RV hot water heater reaches. That's the reason for the mechanical mixing thermostat shown in the plumbing pictures.
In one picture there was a wiring 'rats nest' that wasn't mentioned as a problem now, but will surely become one at some point in the future.
While not being able to take a shower might be a minor inconvienence, flooding the camper with 50 gallons of water might incapacitate the vehicle by damaging some critical system and without an alternate source of drinking water might prove life threatening in some environments. Ask me why I turn off the pressure pump whenever we leave the camper.
The disassembly required to service the refrigerator problem and if my assumption is correct, the fact the diesel hydronic furnace wouldn't operate unless the valves to the engine cooling system were open are more examples of poor 'what if' thinking. Many marine quality 12v compressor refrigerators are available with a remote mounted compressor which can be mounted where the most often maintained components can be easily accessed. My own hydronic furnace and hot water storage tank can operate with the valves to the engine open to either provide engine preheat or provide camper heat and hot water from the engine. But they also function with the valve closed to avoid wasting energy heating the engine or allow for heating if the engine cooling system is being repaired.
Come to think of it, I should add a valve to isolate the hot water storage tank so I can still heat the camper if there is a problem with the storage tank.
Besides the problems caused by the inadequate tubing and poor maintenance access is the nagging concern about what other problems are hidden from view by the pretty facade and where will the owners be if and when they crop up?
I'm glad there are companies making expedition campers to purchase and companies making quality components for DIY, but the design still has to be well thought out and the execution has to meet certain standards.
Food for thought.
