jeep bed slide, slide question
JDaPP
I want to make a slide out for the back of my JKU similar to the frontrunner slide out or a truck bed slide out. What types of slides would work for this application? I would like to have at least a 500lbs weight limit on the slides.
Woodsman
The weight rating of the slides is generally reduced to 250-300 pounds when used for mobile (non-furniture) applications and may also be dependent on the drawer size. Also, if used flat, a 500 pound slide's capacity will drop to approx 100 pounds per pair.
The KV8908 series are the lock-in/lock-out slides. http://knapevogtwp.kv.com/wp-content/uploads/2013/CAB_Catalog/CAB-42-8908.pdf
The non-locking version of this slide is the KV8900 series. http://knapevogtwp.kv.com/wp-content/uploads/2013/CAB_Catalog/CAB-41-8900.pdf
sunnyaz
