Jeep Cherokee parts cleanout
HouseVVares
I'm cleaning out some parts off a never ending Cherokee project I'm messing around with. All of the fuel system parts should fit the 1997 to 2001 Cherokees with the 4.0L engine.
OEM poly fuel tank from a 1998 4.0L Cherokee. It was removed as I have swapped my Jeep to a fuel cell. The tank was working well when I removed it; pump and sender. No external leaks. It will include the fuel pump and sender assembly that was in it when I removed it. I can also include the used fuel tank straps if you want them.
$100
Delphi OEM spec fuel pump with new filter socks and a new tank assembly gasket. This pump is new and has not been used.
$60
Carter OEM spec fuel pump housing assembly (part number P75040M). This includes the internal tank housing, new fuel pump, filter socks, new fuel level sender, and all the hoses and electrical connections. This assembly is new in the box. Bought for my project but I ended up not using it and it was outside the time period for me to return it.
$60
JCR Offroad fuel tank skid plate. This is used but in excellent shape. No impacts, dents, or gouges. Made from 3/16” steel. Note you will need a set of nut strips or some way to mount the skid plate to the frame rails. See the JCR webpage for more info if you need.
$200
Pro Comp Series 89 rims: 17x8, 5x4.5” bolt pattern, 4.5” backspace (0 offset). I have five of these rims. These are practically brand new, no scratches or damage to the rims. I bought them new and used these for a few hundred miles of local driving then came across a deal on a different size I liked better. So these go back up for sale.
$750
Everything is located in Round Rock Texas. I'm willing to ship the fuel pump and fuel pump housing. The other items I think will be more trouble than its worth to try to ship. Please let me know if any questions. Thanks,
Jeff
dhuss
