Jeep JK Owners - Upgrade to 35 spline axles!
RocKrawler
Supporting Sponsor
DESCRIPTION: 2007+ Jeep Wrangler JK Rubicon 35 Spline ARB Air Locker
APPLICATION: 2007+ Jeep Wrangler JK Rubicon Dana 44 Housings (front or rear)
PART NO: RD157 - Available now!
2007+ JEEP WRANGLER JK RUBICON 35 SPLINE ARB AIR LOCKER
To meet the demand of off-roaders looking to strengthen their current axles without going to the expense and weight penalties of a larger axle assembly, ARB has just released the latest model in their Performance Air Locker Series. Designed for the new 2007 and newer Jeep Wrangler JK Rubicon Dana 44 housings, this new performance ARB Air Locker allows users to gain the axle strength they need from larger aftermarket 35 spline shafts and still retain their smaller, lighter Dana 44 assemblies.
Referred to as ARB part number RD157, this new Air Locker is designed to be installed with aftermarket 35 spline axle shafts which improve the torque range by about 30% over the stock 32 spline shafts that come installed in the JK Rubicon Dana 44. As with other ARB Air Locker models, the RD157 features ARB's patented "timed" locking mechanism that optimizes the Air Locker's internal gear mesh in the locked configuration and increases the unlocking speed all at the touch of a dash mounted switch. Complete with the proven steel reinforced, elastomer bonded annular seal, this Air Locker is designed to handle the most extreme climatic temperatures on earth.
List - $984.94
IPOR Price - Too low to print!
Note: - Aftermarket 35 spline shafts required
- Will work with JK Rubicon Dana 44 housings ONLY
- Will work with JK Rubicon Dana 44 gears ONLY
Now for axle shafts: We offer the Nitro chromoly shafts for your JK to use with this ARB locker. The front is a complete set of 35 spline 4340 CV shafts with lifetime warranty for $1198, and the rear is 4130 chromoly with lifetime warranty for $179 each.
As a side note; These rear shafts can also be used in other applications; D44, D60 and Ford 9" - overall length is 34", but the spline length is 11", so it can be cut down to make your CJ, XJ or any other D44 into a 35 spline setup! They also come in different bolt patterns for these applications: 5x4.5", 5x5" and 5x5.5".
Give Iron Pig a call for all your Jeep upgrades!
Terry - (866) IRONPIG
Clemtiger84
