JEEP RUBICON full overland equipment 40k
tkhalbiz
For sale Super Jeep for trail and overland
Rubicon 2012 80k km
Man lives.
3.6L pentastar engine
Differential front rear DANA44 ratio 4: 10
Soft top and black freedom top hardtop
Optional trailer hitch installed
Electric windows
Electric mirror
Rustproof treatment by Rust Check
Sherlock chiseling
Interior floor treated with POR-15 which protects against perforation of the floor
Suspension: Metalcloak 4.5 dual rate coil, Bilstein shocks, 8 Teraflex adjustable suspension arms, Teraflex 1/2 inch front rear spacer
Steering: Tie rod synergy chromoly, adjustable heavy duty synergy track bar, reverse synergy drag link, Frogfab steering sector shaft brace, adjustable Fox steering damper with relocated fly Stainless steel rear brake line extensions
Front drive shaft Rubicon Express 13.10
Rear drive shaft Reel drive line 13.50
Differentials: reinforced front differentials with sleeve, front and rear lower control arm skid plate synergy, C-gusset synergy reinforcement on DANA44 front, SolidAxel front and rear differential cover, extension of the differential breather, reinforced rear differentials with FrogFab truss, Teraflex HD heavy duty adjustable rear track bar
LED bar 52 with FrogFab fly
LED bar 13 "2400lumens to mount on the loop bar
Flat fender Bushwaker with LED position lights
Genright front bumper imported from California (powdercoat here by 2000 sandblasting) with 3 Vision-X LED fog light - Genright rear bumper imported from California (powdercoat here by 2000 sandblasting) with 4 Genright LED reversing lights - Genright rear tire support imported from California (powdercoat here by sandblasting 2000) with Genright plate positioner in the center including 3rd stop light and LED Loop plate lighting of the RoughCountry aluminum front bumper
Custom Turn Signal Cover (Jeep J8 Military Style)
Textured black front grille
PoisonSpyder Hood Louver
Stubby antenna
Or-Fab rear wing protection (corner) with Maxima LED taillights
Frogfab rocker panel protection plate, Frogfab rock slider, FrogFab engine and transmission plate, FrogFab case transfer plate, FrogFab gas tinque plate, FrogFab front and rear differential plate
5 Goodyear MTR 37 "tires fit on Mag Procom style Beadlock (17)
5 winter approved 35 ”tires mounted on steel RIM
AEV Procal Programmer
Inboard ARB dual-core compressor in the engine compartment
CB Bearcat
CB 102 "antenna
Crossmember frogfab heavy duty
Always synthetic penzoil oil
Radio insane OFFROAD
SPOD
PLATFORM IN THE CHEST
WINCH WARN 10K W / SYN VR EVO
METALCLOAK TWIN COMPRESSOR MOUNT
FRONTRUNNER ROOF RACK JKU
FRONTRUNNER RTT QUICK RELEASE
FRONTRUNNER LIGHT BAR MOUNTING BRACKET
TREELINE OUTDOORS REDWOOD 5 PEOPLE
REDWOOD ANNEX
ROTOPAX 2G GAS
ROTOPAX 2G WATER
SMITTYBILT ATLAS DOOR STEPS
JK FRONT OVERHEAD MOLLE PANELS HARD TOP
FRONTRUNNET DROP DOWN TAILGATE TABLE
GENISIS DUAL BATTERY KIT
OPTIMA BATTERY GROUP 34 RED TOP
OPTIMA GROUP 34 YELLOW TOP BATTERY
INVERTER 300W
12v / USB / 110V SOCKET SYSTEM
RIGID INDUSTRIES SCENE LIGHT
Moog / OUTER TIE ROD END
XPRITE RGB ROCK LIGHT 8PCS
TREELINE OUTDOORS 2.0M AWNING
Vectoroffroad mount bar JKE-Dock 2011-2018 Full Width
Maxtrax ramp
And I forget things
More than 20K invested in overland gear in 2020
Maynerd Mowat
