computeruser
I just finished installing a new Warn M8000 (minus electrical) today, after removing the Ramsey REP8000 that I've had for the past couple years and repainting the mount plate yesterday.
Unlike the Ramsey, it is not possible to mount the solenoids on top of the winch motor on the Warn. This is probably for the best, since the Michigan weather didn't do my Ramsey's solenoids any favors. In hindsight I should have just purchased a winch with integrated solenoids and saved myself a lot of aggrivation, but, well, the false economy of the M8000 got the better of me. So I need to mount the solenoids somewhere else. I'm thinking about putting them above the battery, mounting an L-bracket to the battery hold-down and attaching the solenoid unit to that bracket.
The only problem with this idea is that I'm thinking seriously about doing a dual-battery setup shortly, particularly the Mean Green one that has two Optima-type batteries mounted on their side, one above the other, so I don't have to have my A/C lines rerouted. I don't know if this setup will allow the solenoid assembly to remain up around the batteries or not, but I don't think so. I'd hate to spend $$$ on a bunch of 2-ga wire and then have to re-do it a few months or a year down the road, so I'd like to get it right the first time.
Any thoughts on where else to mount the solenoids on a TJ? I could possibly mount them next to the power brake booster, or maybe up front on the driver's side if I relocate the horn.
Also, any thoughts on why not to use the hole in my mount plate as a place to install the winch controller plug-in? I'll probably install in-cab controls, too. I thought about leaving the controller plug-in on the solenoid box, but would prefer not to have to pop my hood to winch. Any thoughts on this?
I should also add that I had to re-drill the roller fairlead mounting holes and ream out the holes on my mount plate, and may still have to pull it and grind some metal off the plate behind the lower roller. Suffice it to say, there is clearly a value to buying things that are designed to work together as part of a system - using Warn's mount, for example, would have saved me this irritation, and an integrated solenoid winch would not have required monkeying around with wiring - and the whole setup would have been completely installed and working already. Lesson learned, I suppose.
