HiTekRedneck
After months of planning, drawing out ideas, testing said ideas, and taking measurements, our sleeping platform has finally been built. My wife and I built the main structure over the weekend and I worked on the finishing touches over the last few days. Quite the project! We both had fun building it...but only wanted to do it once, so it was overbuilt wherever possible. Total sleeping area is 50 1/2"W x 72"L and collapses to 60"L with plenty of room to lean the front seats back and be comfortable. Headroom is a little tight (we have slept in smaller tents) and I have since removed the soundbar to give us a little extra room for getting in and out. After a shakedown trip, I'll clean up all the edges with a router and hit it with some good outdoor paint. Also need to get the surface covered to give our dog Daisey Mae some traction. Probably going to use a utility rug we have up in the attic, but that is only one of many options we have to pick from. Also narrowing down our options for what to sleep on, thin mattress, foam pad, outdoor furniture cushions, etc. Anyways, on to the pics...
Collapsed, 50 1/2" wide X 60" long.
Extended, 50 1/2" wide X 72" long.
Main structure built. We built it up high to maximize the storage area underneath. Only downside is that it is not easily removed.
Boxed in the middle cubby with 1/4" plywood to store recovery gear.
The back of the platform is anchored to the tub on both sides. It should hold up, but if it doesn't, I'll upgrade the hardware.
Building a platform to mount our water jug. Countersunk the factory seat bolts into two pieces of 1"x2".
Top on the platform screwed down and two anchor points added.
continued.....
continued.....
