JP Marine/Impact Inflatable Boats from Pak-Meister/CobraHeat Tactical Supply
Timothynaustin
Great outfits you goto get one :)
I have the smaller Zodiak version with a Yamaha 2hp outboard and love it, the places I can get to and the skin diving locations here in Tasmania are Fabulous.
Cannot recommend them Higher :) Great bit of Kit to own and use. :snorkel:
cheers Tim A
Need For Speed
Supporting Sponsor
We are delivering a Rescue Series SR470 to the The Punxsutawney (PA) Vol Fire Department next week!
The Dive/Rescue series is one of our most respected inflatable boats. Recently, the series has gone through extensive upgrades, further enhancing its durability. Suitable for a wide range of applications, it is easy to see why the Dive/Rescue Series if the choice for multiple professionals.
The new features of this boat include an increase in material thickness, We are now producing 1.5mm tubes, compared to the standard models at only .9mm. We even went a step further in creating a secondary layer that runs the length of the tube bottoms. This gives a total of 3mm of material for running up on the rocky beaches. All our Professional series have 6 air chambers standard. Safety and keeping you afloat is priority one for JP Marine.
Our Dive/Rescue Series boats are designed to be functional, durable and versatile. Two people can assemble most of our models and have the craft operational in less than 20 minutes.
Specifications:
Length 15' 5"
Beam 6' 8"
Hull Weight 429 lbs
Capacity: 8 persons (2750 lbs)
Motor Rating 60 hp (long shaft)
Tube Diameter 20" (Separate Air Chambers 3+1)
Fabric: Hypertex,1.5mm Coated Material
Factory Warranty: 5 years
Console: Optional
Standard Features:
Non-skid aluminum floor with anodized aluminum stringers
Bow floorboard, wood, black
Marine plywood transom, black
Aluminum engine mounting plate
Reinforcement on tube transom attachments
Standard self bailers with plug
All around rub strake, flat profile, black
Rubbing strakes for beaching on keel and tubes
Eight Carry handles, Soft handle with neoprene cover
Bow handle (Stainless)
Transom "D" lifting rings (Stainless Steel)
Exterior/Interior lifelines (peripheral)
Fifteen Interior tie down D-rings (Stainless Steel)
Reinforcing seat patches on tubes
Two large tow rings on bow (Stainless Steal)
Two large tow rings on rear tubes(Stainless Steal)
Foot/Hand pump with hose
Repair kit with pressure gauge
Storage Bags, Bow bag
Four paddles (alum. Shaft, plastic blade)
jesus m anderson
