Just Differentials Ford F450 4x4 Motorhome on 42's Build Thread
nitro-gear
Supporting Sponsor - Differential & Axle Parts
Here is our current spec list for the rig, you can see the stages we went through to get the rig to this point below.
-Started out as a 2004 Xplorer Xcursion RV / Motorhome 6.0L powerstroke F450 4wd chassis, leaf front Dana 60, Dana S110 Rear axle. Features queen rear bedroom, queen cabover bed, Slideout with kitchenette, 3 Diesel tanks, Propane 5k onan generator, TV, Stove, fridge, dual 6v battery setup, 100 gal freshwater,
-Suspension: 2005+ coil sprung F550 Frontend "fatboy" Dana Super 60 swapped in for better ride, wider track, tighter turning radius. Stock coils w/ 2" spacer and airbags. 12k lb rear OE leaf packs with assist airbags custom solid 1" block bolted into leaf pack. Radflo 2.5" remote reservoir Shocks custom built and valved. Icon Armored truck spec pan hard rod
-Buckstop wheels wrapped in Goodyear G275MSA 335/80R20
-Steering: 05+ F350 Steering box with F550 pitman arm, PSC 10" Hydraulic assist Ram
-Nitro Gear 5.38 Ring & Pinions, Nitro Xtreme diff cover, Eaton E-locker front and Truetrac Rear, rear hubs swapped to 10 lug to match front
-Bushwacker Cutout flares, ASFIR Modular bumper, Milemarker 15K winch, Masterpull synthetic line, Factor 55 Pro Link
-Buckstop 20x11" heavy duty single wheels with Continental MPT81 335/80r20 (41") Miltary Tires
-2007 Grille, headlight update (mirrors soon)
-2007.5 Cummins 6.7L, Twin Turbo, conversion done by Diesel Conversion Specialists in Kalispell, MT. Headstuds, banks intercooler, SCT programming, Edge gauges, SCT & EFI Live programming, Oddessey batteries
-ATS Built 5R110 Torq-Shift Auto Trans, ATS High Capacity Aluminum Transmission Pan, Five Star Torque Converter - Fummins Conversion -- Fits Cummins/5R110
This is the official build thread for the Just Differentials / Nitro Gear & Axle 2004 Ford F450 4x4 Motorhome. For more up to date photos, check our Facebook page album:
F450 4x4 Motorhome FB Album
We were in need of a tow / stay vehicle for traveling to national off road events. Travel in snow is also a bit of a concern. We needed something that could sleep 2-4 comfortable, and still tow 10k lbs. Options considered a Diesel Pusher (too big, 2wd), Truck with camper (too small), Class C (Van type too light duty, 2wd, gasser engine would not suffice), then we found the solution. Also we wanted a vehicle that would showcase the products that we offer. The F450 4x4 chassis fit the bill.
We started with a 2004 Xplorer Xcursion Motorhome This was already a good start. These are a rare 4x4 diesel RV which suits our needs well. Fortunately, Xplorer gave us a good headstart. the RV is a nice 1 piece fiberglass construction, has a slide out kitchen, and queen bed at the rear, and on the cabover. It's also fully set up for four seasons use. It came equipped with a nice Herd Alloy bumper and Alcoa alloy 19.5's:
Although it was 4wd, it didn't really look the part. the home portion of the RV keeps the rear wheels really tucked, and the factory 225/70r19.5 tires are only about 31", which look to small for our liking. Functionally we wanted the additional ground clearance of larger tires. Also a SRW conversion seemed ideal for winter traction and to avoid wedged rocks on the duals when off road.
To go single, we needed a tire with a high capacity. The loaded wet weight is about 14k (5k front 9k rear). The factory duals were rated at 3350 ea (13,400 lbs total rear axle). We contacted Rickson Wheels for some custom 22.5" bolt on steel wheels to run big rig tires. They actually had a full set ready to go that were take-offs from the Turtle V Expedition vehicle. This seemed like an obvious choice, but what about tires? Most of the 22.5 semi truck tires have a highway type tread. We wanted something aggressive. We ended up finding some Double Coin RLB800 11R22.5 tires. These have an aggressive tread, and rated at 6940 lb each. Sounds great, but they measure 42" tall. That's a big step from the factory 31" tires.
To clear the tires the truck was definately in need of some suspension. We wanted to keep it as low of COG as possible so didnt want a big lift. After consulting Bushwacker, we found their Cut-out fender flares would clear bout a 40" tire with a leveling kit on a Superduty. With the help of Ben at National Springs, we found are OE rear packs were only rated for 8750 lb, already too soft. We chose some 12,000 pound pair, and added a custom 1" full size block bolted into the leaf pack. The front we used std Leaveling mini pack. This yielded about 2.5" lift. To minimize body roll we also installed Hellwig 1.5" swaybars and extended front links. Since the rear is fiberglass, we removed the OEM flares and trimmed out about 5" around the arch. Since the singles are narrower we decided to run without flares on the rear.
Aaron & Robert at our local Les Schwab truck center, jumped at the opportunity to try cramming 42" Big Rig Traction tires on a motorhome. Keeping it local helped out here as they offered to test fit them. To their surprise the tires fit great!
The Herd Alloy bumper looked nice before, but was going to require significant modifications to match the new fenderline and would not hold a winch. We contacted ASFIR 4x4 for their new modular front winch bumper, these are great as they can be shipped UPS due to the 3 piece construction. It housed the new Milemarker 15k lb winch nicely!
The timing was good, as we just started stocking a full line of ratios and traction devices for medium duty trucks. This means we have gears in stock for this S110 as well as S130 & S135. The Factory Dana Corporation 4.30 gears were fine with 31's but needed more for 42". We chose 5.38 gears, and a Eaton Corporation Truetrac LSD. This gives us near stock gearing. Actually just a few RPM's lower on the highway than stock. We used our part number DS110-538-OE ring & pinion, MK DS110 install kit, TT 504038 Truetrac LSD and DAN130647 ABS tone Ring. This Monster weighed 173 lbs!
Stay tuned for more to come.
More mods:
-Rigid Industries Interior Lighting and Light bars
-Spyntech live spindle conversion w/ MileMarker hubs
-Nitro 35 spline Chromoly axles
-Nitro front 5.38 Ring & Pinion
-Nitro Xtreme Diff cover
-Eaton E-Locker
-ARB Twin High Output compressor
-AMP Research PowerSteps
-Remote reservoir Shocks
mdmead
Wow, too cool! Thanks for posting this up and I'm looking forward to the next installment.
chilliwak
Are you guys just stocking parts for Fords or do you have gears and rears for other manufacturers? What about old 70s GM stuff? Cheers, Chilli..:)
nitro-gear
We stock millions of dollars worth of inventory every day, if we don't have it we can get it. I'll send you a PM.
Thanks!
brp
Have you guys been happy with your tire and suspension combo? It seems like you fit a lot of tire in there with minimal lift, any rubbing issues?
Any additional detail on your suspension modifications would be great (where did the front blocks come from, are those rear springs custom, etc.), I am looking to do something similar.
I looked into those tires and they look like a decent alternative to MPT81's, roughly 2/3rds the price.
Thanks and cool set-up.
nitro-gear
This is a pretty sweet High Pinion Dana 60 in the F450 Motorhome, but we're ditching it for an 05+ Coil sprung "Fat boy" Super 60. The 6" increase in width will help get our front and rear track in line and give better ride with super tight turning radius:
Marka1
