upcruiser
Perpetual Transient
No more ground camping with the Rover. I mounted this up yesterday.
Ok, got some shots loaded from the RTT install....
It worked out perfectly size-wise to remove the side rail center section of the roof rack. Though it kind of killed some extra useable space on the basket, I can still put dry bags with gear in front of and behind the RTT now.
after wrestling the damn thing around in the yard I trimmed up the extrusion rails, mounted the ladder then removed as much weight out of it as I could before the solo hoist onto the truck.
Madi sat and watched and I think chuckled to herself a bit watching my futility at times.
All mounted and opened up. Although, not pictured, we got the changing room that attaches under the tent, should make for a nice place to store stuff, sit out of the rain, and even work as a bathroom when nature calls.
rear shot
all folded up
side view. I need to remove the side rail on the driver's side as well as I discovered the awning supports won't go in with it in the way.
It centered out pretty well. I definately notice the extra weight on the roof. I think with the tall, narrow nature of a Discovery I, it will definately pay to be vigilant. I think this load would be better suited on my much wider stanced 80 series. I just need to go and test this thing out now. It is going to be so much more comfortable then a ground tent and though I think the sleeping arrangement in the 80 series is pretty good, I believe this will be even more comfortable.
rear shot
all folded up
