I might reach out to you in a few months and see how they are holding up if you don’t mind. How much does the car weigh that you have them on?
I have the Kaisers on a mk4 Jetta.
It's been stripped down a little bit and might weigh 2800lbs or so.
I will say if you decide on them pay attention to the treadwear rating.
While its not a perfect indicator of a tires grip it will give you some idea of the tires compound and how sticky it might be.
Anyway some sizes have a 300 rating while others are available in 180.
automotive.kendatire.com
300 is pretty good for a high performance summer tire but 180 should be stickier than any of the best maximum high performance summer street tires.
For example the Toyo R1R, which is their top of the line sticky street tire, has a 200 treadwear rating.
I got 235/45R17s for my car which has the 300 rating.
If I would have stepped down to a 235/40R17, It is available with the 180 rating.
I did not sort out that that was an option until I received my tires.
So I'm gonna use the poop out of these tires, which I can do in a summer, and get the stickier ones next time if these ones turn out to be ok.
As far as checking in later that's fine but, much like you I probably won't do too much twisty driving in the winter.
I have However, planned a trip down to the tail of the dragon and several other roads around that area at the end of December.
That will be my first real hard run with the Kendas along with a brand new suspension and brake set up.
