Well, Klaus just arrived by way of car carrier this evening! I'll document my build-out here.
Why
I've got a perfectly fine Outback, but I've always longed for a proper low-range transfer case and more room, and as someone who first drove in the 90s, I've got a soft-spot for these older SUVs. Long ago I bought an '02 Isuzu Trooper from Arizona, sight unseen. That was a bad idea, as the infamous 4L30 tranny quickly gave up the ghost. Being either stubborn, a poor learner, or both, I've now ended up buying this Montero sight unseen from Arizona. The previous owner is a cool dude, and it passed the mechanic's check, so there you have it.
Also, I keep wanting to learn how to work on cars. My previous toy/project car was an '02 Mazda Miata (notice a trend here?), but that thing was so clean, low mileage and just generally good that all I did was basic maintenance. It's being sold to help fund the Montero.
Anyway, so far the Montero does not disappoint (except for one unexpected but manageable thing). Assuming that I can turn Klaus into a reliable enough daily driver, I'll probably sell the Outback just so I don't have too many cars around.
What
Having never done much off-road, car-dependent travel, and having two young kids in tow, I'm not planning on anything particularly adventurous just yet, just some short trips with the fam and the occasional solo outing. Klaus will soon move to Kansas with us, where I hope to connect with the folks from Konza Overland and spend some time learning the ropes at places like Tuttle Creek. Come July, Klaus will hopefully make it out to Colorado and hit some of the easier trails in the front range.
How
I'll document my build plan here and update it as I go. First priority is making sure it's safe and reliable and can make the long drive up to Kansas. Second priority is prepping it for some off road adventure.
Why
What
How
- Registration, insurance, etc. ✓
- Give Klaus a thorough going over myself to see what the mechanic missed ✓
- Baseline it
- Oil ✓
- Transmission fluid
- Transfer case fluid
- Front/rear diff fluid
- Coolant
- Rubber parts as necessary, ???)
Front-end repairs. The mechanic pointed out that it would need a new upper ball joint, which was right (in fact, I think it needs both). The mechanic didn't point out that the front-end is way underdamped, almost like the shocks are blown, except Klaus has an almost brand-new Ironman 4x4 lift, so I'm not yet sure what's up there. In any case, I'll have to sort out the damping, will almost certainly replace both upper control arms, and double check the lower arms/joints and tie rods. The CV joints seem to be in decent shape at least, and the back suspension seems to be fine at first glance anyway. Replace broken front shocks. ✓- Fix squeak from driver's side front suspension ✓
- New General Grabber ATX tires (the old ones still have tread but they're pretty dry) ✓
- Alignment ✓
- Professionally inspect airbag?
- Grease ball joints on both sides
- Check radiator cap to make sure valve is still present ✓
- Replace radiator cap ✓
- Replace fuel pump. Car has trouble starting unless I leave ignition on for a while, probably the check valve is busted. Will want to do a fuel pressure test to verify.
- Try BG 44K fuel system cleaner
- Brake fluid
- Brake pads and discs (still okay, but starting to get a bit low)
- Squeaking in back (may be brakes, not sure) ✓
- Replace broken bumper/trim clips
- Interior detailing including shampoo (Klaus carried some dogs and I'm allergic) ✓
- Proper emergency kit, including fire extinguisher and first aid kit
- Recovery gear, including jumper cables, a better jack, tire repair kit, portable air compressor, snatch strap and blanket, necessary shackles(?), ...
- Rocky Road supersliders
- Fix small chip in windshield ✓
- Fix chips in paint that have started rusting (clean rust, touch up paint, clearcoat)
Minor leather repair on passenger seat- Relocate climate control and install double DIN head unit plus reverse camera. The previous owner already installed a discrete amp and subwoofer, so I don't have to be picky about the audio on the new head unit.
- Recharge AC
