KZJ78 ATP light comes on when braking
acd2005
Hello All!!,
Yup I have a strange issue on my KZJ78 the ATP warning light comes on when braking...it will stay on for a bit sometimes while the brakes are are still applied and then go slightly dim and go off or if I remove my leg of the brakes the light goes off imediately....
Anyone seen this issue happen before?? Can I try to check something if there is like a short in the wiring somewhere??
Please help!!!
Wallache
Assuming ATP means automatic transmission pressure, then check your transmission fluid level. If its low, pushing on the brakes causes to the fluid to slosh forward, starving the pump of fluid causing a loss of pressure.
acd2005
I had that topped up a bit, it wasnt low....so i guess thats not it.....anything else you can think off? Its probably something to do with the wiring somewhere since the car is left parked for a whole week and only used on the weekends.
acd2005
Just to update..my bad...its the A.T. Oil Temp light that comes on when braking.
As noted the car is an automatic and now also noticing a dim glow occasionally on the same when driving at night so I guess it does come on dimly at times but not always as noticed in the night.
Even when parked and pressing on the brake to change the gear it will light up bright.
Ideas anyone???????
:ylsmoke: :coffee:
Mcoleman
