That is nice!!!
MOT (Inspection) history below in case any one is interested - usually look for things like corrosion, minor stuff is not a problem.
G106YEE
LAND ROVER 127
Check another vehicle
Colour Green
Fuel type Petrol
Date registered 31 December 1990
MOT valid until 4 February 2019
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal.(Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong,
contact DVSA.
Open All
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor.
Find out more
Date tested24 January 2018
PASS
Mileage21,038 miles
MOT test number6888 6980 9404
Test location
View test location
Expiry date4 February 2019
Advisory notice item(s)
- Nearside Front Brake pipe slightly chafed (3.6.B.2c)
- Central Exhaust has a minor leak of exhaust gases (7.1.2)
What are advisories?
FAIL
Mileage21,038 miles
MOT test number9082 2388 3496
Test location
View test location
Reason(s) for failure
- Offside Headlamp aim aimed so that it dazzles other road users (1.8.A.1a)
What are failures and advisories?
Date tested23 January 2017
PASS
Mileage20,868 miles
MOT test number4802 7812 9577
Test location
View test location
Expiry date4 February 2018
- front wippers only just clearing screen
- Front Exhaust has a minor leak of exhaust gases (7.1.2)
Date tested12 January 2016
PASS
Mileage20,838 miles
MOT test number1641 7180 1821
Test location
View test location
Expiry date4 February 2017
Date tested26 January 2015
PASS
Mileage20,710 miles
MOT test number2895 2662 5094
Test location
View test location
Expiry date4 February 2016
- Offside Rear Trailing arm has slight play in a pin/bush (2.4.G.2)
- n/s/r and n/s/f tyre edges cracking but no cords showing
Date tested5 February 2014
PASS
Mileage20,653 miles
MOT test number9756 1643 4027
Test location
View test location
Expiry date4 February 2015
- n/s/f and n/s/r tyre side tread cracking
- rear tie rod bushes slight worn
- n/s/f hub slight oil leak
Date tested17 January 2013
PASS
Mileage20,289 miles
MOT test number7459 9701 3041
Test location
View test location
Expiry date24 January 2014
- Centre Front Exhaust has a minor leak of exhaust gases (7.1.2)
- Offside Rear Tie bar/rod has slight play in a pin/bush (2.4.G.2)
- n/s/f tyre slight cracking outer edge
- slight leak n/s/f hub oil seal
FAIL
Mileage20,289 miles
MOT test number9257 5701 3001
Test location
View test location
- Offside Front Windscreen washer provides insufficient washer liquid (8.2.3)
Date tested24 January 2012
PASS
Mileage20,061 miles
MOT test number1996 6432 2093
Test location
View test location
Expiry date24 January 2013
- Centre Exhaust has a minor leak of exhaust gases (7.1.2)
- Rear Exhaust has a minor leak of exhaust gases (7.1.2)
- slight oil leak from n/s swivel housing
Date tested25 January 2011
PASS
Mileage19,859 miles
MOT test number8778 2592 1069
Test location
View test location
Expiry date24 January 2012
Date tested18 January 2010
PASS
Mileage19,572 miles
MOT test number7109 4841 0048
Test location
View test location
Expiry date19 January 2011
Date tested20 January 2009
PASS
Mileage19,367 miles
MOT test number3932 8072 9029
Test location
View test location
Expiry date19 January 2010
Date tested15 January 2008
PASS
Mileage18,812 miles
MOT test number1011 9521 8497
Test location
View test location
Expiry date14 January 2009
Date tested23 November 2006
PASS
Mileage18,216 miles
MOT test number4328 8762 6424
Test location
View test location
Expiry date22 November 2007
