FEF
All,
I've got my fuel tanks mounted, and I'm to the point where I'm giving more serious thought to my choice of trailer. As there are engineer types here, and you guys don't laugh at the idea of trailers, I thought I might see what you all thought.
The question is... What forces change, when you replace a fifth wheel pin box, with a pin box that has a pintle ring on the front?
It's easy to see how the center line of the vertical load changes. There will be a cantilever action, with the front of the pin box as the fulcrum. I can easily account for that.
The pin box will want to rotate, as I drag the trailer left and right. That shouldn't be hard to account for, too. That happens with extended pin boxes.
All the other forces should be similar, right? As I've seen short pin boxes, and extended pin boxes, the pintle hitch on a short box should not be any worse then the fifth wheel pin on a long pin box.
In fact, what I'm thinking about doing is having a pin box made that will have the fifth wheel pin on bottom, and a pintle ring on front. Setting up the truck is easy, and not an issue.
Any thoughts?
Thanks for the help,
Any thoughts?
