Mine has only leaked with a ton of snow packed on slowly melting. I think that was because the snow blocked the normal exit for the water and it backed up into the windoor channel. I've not noticed anything during standard rain events.
You didn't say anything about the ARE age or location? I do not have an ARE, but here in Colorado due to the extreme UV and temp changes, all gaskets dry out and need replacing sooner or later. Also you might check to make certain the cap has not shifted placing a bind which may cause a leak. Just some thoughts. Good luck!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
