jacobconroy
Hillbilly of Leisure
Hi,
I'm at the point with my van build where an ASME propane tank is needed. I've found a 10 x 42 inch ASME tank from a salvage Ford 1-ton motorhome (for $150.00) and it will fit in the space I have. The math leads me to expect that this tank will be hold about 10 gallons and give me around 8 gallons of propane. This should run my Propex heater and cook stove for a whole summer unless I use a propane fireplace during burn restrictions.
So, I'm wondering about clearances for an RV propane tank. My muffler is within 24 inches of the intended tank location and that bothers me. Some searching for clearance specs turns up stuff for giant propane tanks. Not much about RV installations. Also, I plan to install my Propex under the chassis by either building a cold-rolled steel protective box or replacing it with the new 2211 model. This would probably lead to some clearance issues too (combustion exhaust and propane lines running near van exhaust).
I could just run propane lines inside the van (and mount the Propex inside) but I like the idea of keeping all that crap out of the living space. It would also be easier to tinker with the Propex under the van because I have about 20 inches of clearance below. If it is inside I wouldn't have much space for maintenance and troubleshooting.
I can't be the first dude to tackle this? Can anyone provide any tips from experience? I'd appreciate it!
