Lighting question
Oil Town XJ
If you could only run 2 Hella 4000's on the front of your vehicle, would you use euro or pencil beams?
I plan on converting them to HID
StumpXJ
SE Expedition Society
Unless you are doing high speed (wide open land)desert runs, forget the pencils. Seriously.
The Euro/driving light is MUCH better.
~ Stump
Hawk Thor
I had Hella 4000s with 100W halogens, both euro beam and pencil on a previous rig. I had two of each and the euro beams were much more useful.
I now have two euro beams on my Land Cruiser with 55W 3000K HID and they outshine 35W factory HID Hella 4000s. The beam pattern is not as good as the Hella 4000 Xenon but they light up a bigger area.
The light shines as far or further than the pencil beams with 100W halogens and the light is spread over a very large area.
I have one pencil beam Hella 4000 which I have converted to the same specs as the euro beams. I just need to weld a tab to my light bar to mount it between the euro beams.
That said I would recommend getting the two euro beams.
You could also run one euro beam and one pencil if you convert them to HID. I have heard about people doing that with good results, but have not seen it for myself.
I will disconnect one of my euro beams when the pencil beam has been mounted just to check it out. Judging by the light that I get from two euros, the mixed pair should do very well.
There is one thing I miss about the halogen bulbs though. The HID throws so much light that I have to switch them off very early when someone is going to pass me or when someone is in front of me. The HID has almost limited the euro beams to off-road use only, where as with the halogens I could use the euro beams as extra high beams.
PV Hiker
On two different trucks have been running a Euro on the driver’s side and a Cornering light on the right. I have the inside toggle switch to turn on the Cornering light with the low beams are on, and flipping on the high beams also turns on the Euro beam. If you have never seen the pattern of the Cornering light, you’ll be amazed what you can see like deer and elk on the side of the road. It shines a even light wide right to left and the distance is pretty good. Both are 100w bulbs.
I recommend 1 euro and 1 cornering.
Supreet.dhaliwal
