Locked Hitch Pin - Need Removal
adventureduo
Dave Druck [KI6LBB]
Ok, so the PO of our Sportsmobile had a locking hitch pin in the 2" receiver... and he gave me the keys, but they seem to be the wrong set of keys for it.
What's the recommended method for removing such item?
I mean, if i use a torch it's gonna flame holes through other things... maybe a plasma cutter?..n but that could cause havoc too blowing holes through stuff. Maybe a sawzall?
Anyone ever lose their key and had to remove a hitch pin? :D This could potentially suck.
Oh yeah, i cant read the thing.. so no dice contacting the manufacturer for another set of keys.
With a thin .040" wheel?
How about freezing it with freon or liquid Nitro and then hitting it with a hammer?
Bolt Cutters?
One of those wire saws, although meant for wood?
How about a jewlers torch - easier to control in a tight space.
You could use a ARC stick welder and just burn through it on a high setting. Dont forget the spatter blanket and plenty of personal covering!
Brian
The die grinder might be my best bet.
I dont have anything to freeze it with lol
Nor do i have big enough bolt cutters or a jewelry torch.
And im trying to stay away with anything with a flame LOL!
Keep the ideas coming. This is fun! :victory:
Mongo here. I let one get a little too much moisture in the keyhole with out regular cleaning. Key wouldn't turn. Big hammer and a piece of metal to put against the lock portion. Wham! Twice and it popped off.
BTW don't let the criminal element read this. Shhh!
Perfect!! Im a big guy.. i'll give it whack!:elkgrin:
:archaeolo SOCALF, I have "MASTER" locks all over my stuff and they have a VERY TIGHT CUT KEY, BUT
Their UNLOCK direction, is CLOCKWISE, not counterclockwise--check it out and Fiddle a little, with the key insertion !!
GOOD LUCK--JIMBO
Uh, yeah, don't force it, just get a bigger hammer.
I have had good success beating them apart. Failing that, a good lock shop will have a ring of keys cut that you can try and try and one will likely open it.
If it gets to be too big a deal, PM me and I will take the SMB off your hands.
I had a similar situation and went to my local lock smith. He had it off in about 2 minutes and I think it costs around $10.
Bobbyjr
