Look at this ?
Peter_n_Margaret
Some vehicles are particularly prone to stones jammed like that. Friend with an earlier Defender has had the same happen a couple of times.
Generally hear them screech if you go into reverse, but the wheel has to come off to get them out.
Cheers,
Peter
OKA196 motorhome
HUMMER/Expeditions
The road in that section was a more rocky than gravel, mostly rocks 3 to 5 inches.
the old defender broke another ARB heavy duty shock in the back.
Hey ARB stop using Poor quality materials and call it a heavy duty.
First time ARB changed the shock under warranty in 2020 and here it goes again.
HUMMER/Expeditions
There is a flat bracket there
We assume that’s where the rock got stuck at first.
See how that is bent and folded.
SkiWill
You're both wrong. It had to be the air suspension. Most likely an air strut exploded and took out that bracket. It just used the rock as a disguise.
billiebob
And this confirms my commttment to solid axles, front and rear.
Freak, common or not.... not an issue on a Wranlger.
When you bend a Wrangler steering knuckle... the BMW looks like this.
A.J.M
Can someone explain how having solid axelswill stop a rock getting wedged between the brake callipers and the wheel.
Given that solid axels also have wheels and brake callipers.
Or is there a rock repellent brake callipers that is only available for solid axels?
Baartmanusa
