Look! Yet another "the fridges are too expensive!!" thread :D or - day trip fridge
urbex
I already own an Engel fridge, and yes, I'm totally on board with the "fridge beats a cooler any day!" idea. I love that thing, and have repeatedly said there's no way I'd ever go back to a regular cooler again, if for no other reason than just not having to visit the gas station to buy ice every time I go out, lol. I love that I can pack up the night before a trail run, and just get in and go the next morning.
However, a new wrinkle has been induced in that plan - I picked up a compact SUV for easy trail work and day trips. A 2002 Suzuki Vitara 4 door, to be exact. My Engel is a MT60 model, and it's a monster compared to the available cargo space in the Suzuki. With the rear seats up, it basically takes up about 90% of the available cargo space. Plus, the capacity of this one is a whole lot more than I realistically need for a non overnight trip by myself or with one other person.
The Suzuki really is a day trip vehicle to me, I have zero intentions of using it for a week long camping trip, or even a weekend. MAYBE a single night, but even then, I'd be much more likely to take a different, larger, vehicle if that was the plan. So I don't need to be able to keep several days worth of food and water cold. I'm thinking something like the Engel MT27 would be plenty of capacity for this. So I looked at the smaller Engels, and found they're not all that inexpensive either. Nor are the Edgestars. After buying the Engel, coughing up another $500+ for a second fridge is a bit hard to justify.
I contemplated picking up a thermoelectric cooler, since battery draw would be less of a concern as I won't be running it on battery alone overnight. But since I live and play in the southwest desert, I'm concerned about them not being able to keep up at the temps go into the 100F+ range. But I only have experience with the WalMart type cheap stuff. Do the better brands do any better? Is there even such a thing as a better brand of thermoelectric?
I'm also wondering if I would just be better off to buy a small ice cooler, and invest in a decent amount of the reusable ice cubes instead? Or maybe even a bit larger, cheap, thermoelectric, and use the reusable ice cubes in that as well to help it out a bit?
Looks like you are a candidate for a Coleman Extreme ( less money ) or going first class - Yeti. Both work in your environment
for several days without need of ice replenishment.
A Coleman Extreme would be less money but take up about the space of a fridge. A Yeti would be about the same in cost and size.
After Labor Day start looking on craigslist. Earlier in the summer I saw a few 30 and 80qt (I think people thought they were too small and too large) fridges for sale. I imagine that after the season people might be selling their smaller ones in hopes of getting a larger size.
Chad
I got my 63qt Edgestar for $212.xx scratch/dent; would a 43qt be a reasonable size? If so, I'd keep an eye out for a scratch/dent model.
how large of a cooler are you looking to get dimension wise to fit?
It's not so much a matter of "how big can I go?", but rather one of getting something with a reasonable capacity for single day trips. I'm sure if it really came down to it, I could figure out a way of getting my big Engel in there, but then it's a lot of wasted space and capacity. From prior experience, my Engel is overkill even for an all weekend trip for me. For that matter, even my 40 quart ice cooler tends to be more than enough for a weekend, and the last overnighter I took it on (without the fridge), it seemed like I barely even made a dent in it. I'm thinking for my day trips, even a 20 quart would be plenty, and I could probably go even smaller. Just to use the Engel offerings as an example, I would likely be looking at the MD-14 and MT-17 models.
Right now, I have a cargo floor dimension of 24" deep by 40" wide, with the rear seats up, and without accounting for the space that tools/spare parts/equipment/etc would take up. I'll likely be removing the rear seats for additional depth as I don't have kids/pets/etc that go along with me, and I'd like to be able to maintain the ability to sleep inside, just in case, without having to put gear outside. While I don't intend to use this vehicle for overnight camping, I'm thinking along the lines of an all day trail run that went late, and I wanted to get some rest before a long drive home. I determined earlier that with the front seats reclined all the way, and rear seats folded flat, I had just barely enough room to get a twin sized air mattress in there. The front of the mattress would go far enough forward that it would essentially be touching the gear shifter in park. Since I'll have other gear in the truck at all times, I'll have to make up some kind of plywood base that would extend far enough front to rear that I could put a sleeping pad on.
Stanley makes a nice 16 quart Adventure cooler that holds ice for 36 hours. I have one and love it. You can pick it up as low as $48 on sale:
So basically the consensus for these situations are "use a cooler, and just deal with the ice" then? :P I figured that's where I'd be headed with it.
If the intended use is for a day trip and single night max, then a cooler should fit the bill. the question now is how much stuff will you be looking to load in the cooler for one of these day trips/over nighters and then get the cooler size that matches the need.
An alternative is to figure out how much space you want to allow for a cooler to take up in the Susuki and then just be content with what you are able to fit in it. With space in the Susuki being primary reason for your post, I suspect this may be the better approach to take.
A soft side cooler will squeeze into tight areas using less cargo room. I've been extremely happy with my norchill 24 boat bag. I use two Nu Ice ice packs and pre chill the items I take with me and it lasts a min of 24hrs.
Norchill usually has a 50% off deal if you mark their name on any cooler and send in a pic of it, best $30 I've spent in a long time..
I use the smallest version of this as a lunch box. I highly recommend it. In my line of work, things take a ******tkicking, and it's held up well.
tbnd88
