Looking for Tongue box with side door instead of top
Josh41
Any one ever see a tongue box like this with the side opening? I would love to replace my top opening and put 2 bike trays on it.
emtmark
Austere Medical Provider
I flipped two on their side and mounted them on my scout trailer? Got them from harbor freight. They have one their that has a zero clearance lid?! It will open to the front, unless you bought 2 put them is at an angle \ /
billiebob
If you can't find one, it might be a unicorn, you could buy a door, cut the hole, bolt it on.
Bike trays on the top correct.
Have you called the camper manufacturer pictured ?
NatersXJ6
There is another thread on this a few months ago. IIRC A source is identified but they are $$ and heavy. Have you run a search?
Those are pretty much custom. I'm having one made for my custom off-road teardrop. One side will have a 75L fridge/freezer on a slide, the other side battery and electronics. Cost to me via a welding friend will be about $1000. cdn excluding the slides.
ScottReb
We'd gladly build you one, even put a custom designed rack on it for ya, but being on the other coast is tough for shipping. Any decent fabrication shop should be able to make one, but it won't be cheap.
tatanka48
big truck trailers use them under the edge of large flatbeds
and so do some welding truck/custom pick up flat bed manufacturers
giggle "flat bed truck tool boxes" and you'll find bunches of all sizes n shapes along w/ sources
they are commercial grade units so expect $$
"T"
SANelson
