Nailhead
I just raised my '85 8' CO for the first time since I brought it back from Portland, OR in February. In the course of lowering it, the front would lower much faster than the rear (this makes sense to me with that extra weight hanging out so far beyond the lift rams) and then the whole system would bind up.
The only way I got it to lower was to barely crack the valve on the jack, lower the top VERY slowly, and hang off the rear of it in the doorway when it started to bind up. Not fun (being over 50, out of shape, and portly), and not sensible.
I imagine I need to lube the slides between the two halves, but other than that, I'm out of simple solutions. The other idea that came to mind was to install a metering valve on the front lift circuit so more pressure gets to the rear circuit and maybe evens the lift/lower action up. I'd REALLY rather avoid this because of the mess that's likely to involve.
Any other ideas?
Any other ideas?
