Lowrance Baja 540c mounted in a 80 series?
adventureduo
Dave Druck [KI6LBB]
Anyone here mount one in a 80 series? Things are massive and I was wondering where you guys may have mounted them.
Thanks!
Ok, here's what i did. RAM mount for the same Lowrance fishing model *(which is the same exact housing). Found it at west marine, didnt even have to order it online! Thing works so perfect, its at perfect height, i can easily operate it and i can adjust it to any angle , plus I can rotate it so the co-pilot can see the gps.
Excuse the dust.. the rig is filthy, hasnt been cleaned since the last trip..
pics..
I can still fit my old Garmin behind the new Lowrance if i wanted to too. I just left the mount there. In case i ever needed to use it.
That's the other thing.. ZERO vibes! And im saying that with it screwed into a plastic console piece! Just imagine after i strengthen up the console! This mount is made for this unit. Now i know why everyone buys the RAM mounts. Kind of spendy.. but hella strong (metal) and well worth the money.
Not really.. cause shes little.. but if it was me.. it would kind of suck (im 250 lbs). I can adjust it so its not on the co-pilots side at all.
Was thinking of addine a 540C to my rig as well as it's a large screen. Did you put a plate under the plastic (backing plate)..... or just screw into the plastic?
This was my solution. The only issue I have is that with polized suglasses on the screen is blacked out looking at it straight on. Viewing it is no problem. If it were a 130 mph race truck I would not recommend it there but at trail speeds it seems to be no problem to look down at it.
The aluminum is 1/8 thick, it extends 1 inch under shifter plastic box. Had to releave box 3/16 inch where the bracket slidles under. I have not replaced the factory rubber piping at the box yet. It ends ups being extremely sturdy, I tested this past weekend on trials rated at 6, no vibrations.
2eleven
