Victory_Overland
I have my Traxide kit laying in the garage and am laying it out to get a good plan. I think I am looking at making a few changes to the rear harness 12v plugs and go to a Blue Seas 6 or 12 accessory box but not sure yet.
With that said, I am running the following batteries and I plan to buy a new charger (potential hardwire) to leave under the hood since there is no chance my lovely LR3 super weak-****** factory alternator will ever charge those AGMs up to full spec on a daily drive scenario.
I've been doing research and am sold on a smart-charger! I've been researching a bit on NOCO Genious and a bit on CTEK so I am curious to know who is using what for their power needs.
Anywho, here is the proposed set-up. I put this under our forums since the LR3/4 is entirely sensitive to specific voltage requirements and having solid charge requirements without shutting the vehicle down into limp mode.
Proposed Set-up:
Traxide 160 with solar/caravan
Primary: Odyssey AGM PC1350 cranking/starting battery
Auxiliary: Odyssey AGM PC2150 deep cycle 100ah (this is minimum but if I can find a bigger than 100ah that will fit I'll do it)
Solar Controller: Victron MPPT 15 amp Bluetooth (I'll wire the controller and Andersen plugs in, panels will added later)
Fridge: National Luna 50L
Air Comp: ARB dual
I'm not really looking for voltage requirement stuff as I plan to be somewhere around 270w of solar panel when complete.
Proposed Set-up:
Air Comp: ARB dual
