LR4 FRONT 2" receiver via OEM winch mounting holes
Elumeno Pee
I recently purchased a 2013 lr4, and am wanting to install a front 2” receiver. Does anyone have diagrams or good photos of where the OEM winch mounts? I am hoping to run a Piece of 2” tubing perpendicular to the car and weld tabs on each end to line up with the mounting holes. Then run the receiver out the front bumper. That way I can throw my winch tray on front or get creative with backing up my trailer. I've seen pics of the OEM winch, and assuming the hide a winch's use the same mounting holes. but I can't find any instructions or good detailed photos of exactly which and how many etc. if they are just tabs or have nuts welded on etc etc.
I'm installing a hidden winch next week; If you don't find your answer by then, I'll be sure to drop some pics here.
Whoops. Went out of town and forgot to post pics.
Note that the silver canister on the passenger side of the A/C condenser is the only thing that prevents the 8 frame hole from being horizontally unobstructed. On the winch plate I bought, it comes with spacers about 1" long that space the winch plate off from the frame to account for aforementioned silver canister.
Measurements:
Outside holes, center to center on the horizontal axis: 34.75"
Inside holes, center to center on the horizontal axis: 29.25"
Holes, center to center on the vertical axis: 5.25"
Do keep in mind that this is an LR3. Hopefully this helps!
sebsync
