Who’s running a Tuffant steely on their LR4? I’m wanting to run the 274/70r18 and need to know If ET44 will allow clearance on inside…steering knuckle,etc. Or if using the ET27, do you encounter problems on the outer edge as the steering radius angles are greater and further from pivot point? For reference, Terrafirma with ET44 requires a 30mm spacer which I believe puts offset at 14, even wider stance than these ET27 Tuffant, which tells me they should be ok. Thanks for the input and I know there are other figment concerns under the fender(horns, heater lines, SYA spacers, etc.).
