IMO lift rods are pointless. They just trick your EAS to remain at a higher setting by mechanically preventing them from lowering below standard height - you lose access height and Off Road 1 effectively becomes "standard." You get zero additional ride height.Johnson Controls offers some lifts for them that dealerships were installing new.
As others ahve said, Lucky8 LLC has a lot of what you'll want - e.g. Proud Rhino off road equipment, Compomotive off road wheels, etc
That clearance is available any time you want it with the push of a button at no additional cost, and at no cost to ride quality. And lift rods don't give you any *additional* ground clearance. Even here in the Rocky Mountains I haven't found many situations where more than eleven inches of ground clearance hasn't been enough, but as a daily driver I do find that I need access height for family and the occasional parking garage. These aren't rock crawlers, and lift rods won't make them so. If you want to do that, buy a Defender and get a 2" subframe lift for under $5k. Or if you want more command over lift modes and other functions, get a GAP tool. The $500 will pay itself back.Yes, running with lift rods is not perfect as it doesn’t really improve travel and you need to manually select normal height after selecting 4 low to avoid driving around in full extended height.
But you do get more tire clearance by ensuring the truck always rides in off-road mode. That, and general appearance is why most people use them. Also worth mentioning $100 for a simple lift (similar to a spacer lift) is a lot less than taking a Land Rover to j-Austin and spending $15k on a real lift ;-)
Driving in the desert, I'd just go with sliders, a bash plate, 18's and 70-series tires that can be aired down. That's sufficient for sand and rock - tire construction and running pressure while overlanding in the desert are more important than OD. 33 inches on a 70-series tire is plenty of tire.
I can fit a 32+" OD tire/wheel in the spare location and there's room left. 265/70-18 is 32.6" OD, and there's easily more than an additional 0.3" between my current 255/60-20 spare and the inside of the spare tire well.Are you able to fit a 265/70R18 in the stock spare tire location?
... and I'm not sure I want to know what the Defender 130 will cost...
