M101 CDN 12V bulbs?
Is there a direct replacement 12v bulb for the M101 CDN/M416 lamp assembly? I am assuming I have the 24v setup, as they're really dim (still work, just dim).
Anyone do a replacement? Would this be as easy as heading to my local auto parts store and getting the replacement?
And is anyone aware of which is which when it comes to the bullet plugs on each side of the frame near the tail lights? I need to hookup my License Plate lamps.
After trial and error (and probably a gallon of gas while idling), it appears it's the forward-most bullet plug on each side. (The Canuck style differs slightly from the pics in the US manual.)
Ghostship
Top bulb uses Bulb#67 12v replacement
2nd from top uses Bulb#1156 12v replacement
You can do some cutting/splicing to convert the blackout lights into turn/stop or running lights (using same bulbs as above).
You can also just swap out the whole tail-light assembly with Truck-lite LEDs part #07240 (or 07411) ( www.truck-lite.com ).
