M101 CDN2 Wiring
weather
Hiya, No response to my last thread but I'm looking for wiring info on my M101 CDN2. The whole manual would be awesome lol but wiring diagram would be just fine too.
The best I could find online is from an Ih8mud post from 10 years ago:
21, running/parking lights
22-460, right turn signal
22-461, left turn signal
white wire to good ground on the trailer
Can anyone confirm this? Also are running/parking lights AKA brake lights?
high-and-dry
some places to look
this post if from 2004 but the guy had full manuals might be able to track him down
VanIsle_Greg
This might be what you are looking for? If not, it is pretty helpful for anyone who owns a CDN M101.
Full owners manual.
  • M101CDN_Trailer_Manual.pdf
weather
In case anyone in the distant future is converting this trailer to civilian 12V wiring and the pdf above isn't accessible, see the following pin designation as indicated by the aluminum clamps on the harness located behind the welded-on tongue support bracket:
21 - Left/Right Clearance Lamp (AKA Marker lights)
23 - Left/Right Brake Lamps
22 461 - Left Signal Lamp
22 460 - Right Signal Lamp
These will be the important pins if wiring with a 4 pin or 7 pin trailer harness. There are no reverse lights on the OEM military but I may try wiring the reverse lights to the following pins to see if that gives me anything.
24 484 - Left Black Out Lamp
24 483 - Right Black Out Lamp
Bulbs will also have to be replaced with 12V units.
__kmg__
