M416 Based Expo Trailer w/RTT and Goodies $5750
1967 M416 totally rehabbed and modified.
Here is the build thread:
https://www.expeditionportal.com/fo...th-3-girls-an-m416-build.192489/#post-2466266
3500lb axle with 5x5 lugs to match the JK.
33" tires
Raptor lined entire tub with exterior painted gray over raptor liner
Completely cleaned up frame and extended tongue
New oe springs
Rear hitch
3 point sidewinder Jack's for leveling and stabilizing
Custom made utility rack with 360° lighting
Tub lights
Led markers and brake lights
Tongue box with deep cycle battery and control center
Smittybilt overlander xl rtt and annex.
Since posting the build thread I've added other conveniences:
Added 2" gel memory foam mattress pad over existing 2" mattress pad
Removable 5 ft long stainless table
Axe and shovel mounts
Drop lunette receiver
Have a second set of steel wheels and tires (30"x16") that fit under fender
I'm in Pittsburgh PA a d have no problem showing it to you and demonstrating it's abilities!
$7000 obo
How high is the tent mount? Approximate is fine.
Thanks
Approximately 65" off the ground to the top of the rack. I actually designed it to fit into a 6'6" garage door opening with the smittybilt rtt on top but was heavy an inch. So now I have to air down my tires to out it away ?
Alexk
