M416 Lift Kit?
4runnerteq
Is there such a thing? New leaf pack? Add leaf? Id like my trailer to sit a little higher, but flipping the axle just looks to be a little unstable to me. Changes in "pullability" ? It doesnt really need any more ground clearance for what I do. Im just thinkin down the road with a RTT mounted directly to the lid it would be a little higher. Not that it even matters. Experience pulling after flip or some type of lift?
mep1811
Gentleman Adventurer
You can do a spring over. No issues with towing but you should not use LT tires, use shocks and low tire pressures on the road and off road
Kflash
I am replacing my C shackles with new ones. They haven't arrived, but I backed them half out and sprayed them good with WD40. Man, they are in there tight. I had to use a 3 foot 3/4 inch breaker bar. Note: The divers side lower is the one with reversed threads. Another post said it was the passenger side - Nope. Maybe mine were on backwards? Seemed to be the originals.
Question -Does left had mean Driver and right mean Passenger?
Back to the question - what if you used a lift shackle? Might give you a little more height?
