They have a couple versions. I don't recommend the stand alone Verandah, appears to be designed for European camping. A heavy, fiddly thing to set up in the spring and take down in the fall. A basecamp to store your gear.
Changing rooms have also evolved, the first ones were pretty simple, an awning with zip in sides, not bad quality, but you couldn't set up on pavement because it needed to be staked down. The latest version appears to be much better with support bars running under the tent. I haven't seen one of the new ones up close though so I can't comment on the quality.
