Making a swing out tyre carrier/bike rack for the rear of the trailer
djaraceandrally
Adventuring somewhere...
Hello,
I am looking into fabricating a swing away rear frame to carry the mountain bikes, but still allow access to a door on the rear of the box.
My question is what are you using for the load bearing pivot point? Ive seen what i think is a small trailer wheel hub complete with 4 wheel lugs, turned upright. I was thinking along the lines of a bush type fitting rather than a bearing??
Any ideas?
PCO6
I took a different approach that may work for you. The tailgate on my trailer is hinged on the right the same as my Jeep. I have a 2" receiver on both the Jeep and the trailer (Class III frame on the Jeep / tube welded to the bumper on the trailer). I bought 2 roof top bike racks and attached them to separate hitch inserts. The first rack goes into either the Jeep when I'm not trailering or into the trailer bumper when I am. If I'm taking 2 bikes the second rack inserts into the first one. I can take both bikes off the racks in about 10 seconds. The tailgate(s) then swing open over the rack(s).
In my case I didn't want to swing the bikes but I can see where others might want to.
Here's mine ...
No bikes ...
picture.php
One bike ...
picture.php
Two bikes ...
picture.php
K2ZJ
Double heim joints or johhny joints like this:
Or the spindle idea you mentioned minus the studs (click): EDIT: This was posted above but I was typing a distracted so late post.
Or pin and sleeve like this?
djaraceandrally
Thanks all, need it to swing away and still be attached, so using a 2 inch reciever hitch idea will not work for me but the actual type of bike racks you showed looked to be a good idea ( i was looking at the ones that you hang the frame on). So will look into making a swing away using those heim/rose joints and fitting my lights, reg plate and rack to it.
97kurt
For swing outs, I have always used flanged bronze bushings in a DOM sleeve with a grade 8 bolt going through them. Mounted in double sheer. You can get the bushings from Mcmaster super cheap ($3 each).
The first bumper I made I used a 1" grade 8 bolt which was super over kill. My current bumper with a dual swing out uses 3/4" bolts. The trick to making it last is that its properly supported when its latched so that there is no movement.
mackyfranklin
I realize this thread is old, but I ended up here while searching for info about making a swinging bike rack and it helped me with my final design. I ended up using the heavy duty spindle kit from Comp 4x4 and built a custom bumper that holds a 6-bike Recon Rack. Used a pop-pin to keep it in place when it's open. Swings super smooth, even with 6 bikes on it, and doesn't sway while driving. Super pleased!
Anyway, I figured I should pay it forward and include links to a couple videos I did about my rack in case it helps someone else. Disclaimer: these videos are NOT how-tos, but more about issues I ran into and how I fixed them.
Update: Turns out I can't post links (maybe too new of a user). If anyone is interested, the videos are under the 'van build' playlist on my YouTube channel (the base URL then "/sydandmacky").
IvaBru
