The Campulance Man
Hi all - I have an '02 E450 based Marque class III decommissioned ambulance that I've been building into a permanent living vehicle and I'm skiddish about one part of the electrical. When I bought the truck the inverter had been removed. The wiring is still present and was properly terminated, with the incoming AC shore power wired (plugged in to) what was the inverter AC output. This allowed the AC outlets to function when plugged in to shore.
I spoke with a tech at Marque who explained how I put the inverter back in and I now understand that I need an inverter with a transfer switch. No problem. I've spoken with AIMS Power and have selected an inverter/charger with transfer switch.
Now my question concerns the stand alone charger that the truck also has. This is a 45 amp AC powered charger/power supply that is plugged into AC power and it's output is wired to the the main house DC switch on the side of the drivers seat. It's attached to the hot side of this switch, which tells me it's feeding the batteries. From what the previous owner told me, when plugged into shore power the batteries get charged. This converter/charger is obviously doing this.
Here my question - with my new inverter/charger can I simply disconnect this stand alone charger?
Unfortunately Marque has no records from my trucks era - they've been sold 2 times and told me the older records didn't come with. I was lucky enough to get a tech on the phone but can't rely on that as a support resource. Is there anyone reading this that can give me some insight on my truck? Thank you reading this far.
