I've heard that for IFS vehicles a 4" lift is the limit because the upper control arm basically touches the coil and going further would begin to affect the drivability of the vehicle, is this true?
If so, it's unclear to me if at 4" I would still get full wheel travel or if even at 4" wheel travel begins to get sacrificed?
Also, if it's leveling the front of the vehicle does that still count as a lift?
Additionally, for example, the Chevy Colorado ZR2 is lifted 2". Are the CVs and everything corrected for this, which means that I can get another potentially 4" of lift, or is everything left the same as an LT Colorado, for example, and the 2" just lifted for the ZR2 so that they actually do count against lifting further?
Furthermore, if it's a solid axle vehicle is the sky the limit in terms of lifting the vehicle?
Also, I've heard that lift blocks for off-roading are a bad idea, is this true?
