Kuneefay
So I thought Id introduce myself. Im a complete newb when it comes to cruisers and toyota in general and consiquently i've been diving relatively blind. I spent a couple days researching these forums and slee's site which helped quite a bit. I pulled the trigger yesterday and picked up a 1993 fzj-80 with the 1fzfe(which I know next to nothing about). Within the last 20k miles its had a full transmission rebuild, heads resurfaced, a long block imported from japan put in, a 2" OME lift with track bars and caster correction, safari snorkel, sliders, front and rear bumper and piaas put on. Also aquired a few descent body badges from trails. I crawled under it this morning and greased up the driveline and to check for leaks after my commute to work, looks pretty good other than a trans pan leak and a dipstick hose leak which are both liveable for awhile. After a few months of settling in my wife and I's 2nd baby(due december) I plan on throwing my hat in to start volunteering for a local search and rescue group which was the main reason for buying the rig(with occasional daily driving). Until then I plan on putting some elbow grease into it and replace the passenger rear door(descent dent and lock/window doesnt work on it), putting fender flares back on, full synthetic redline oil swap to everything, cross drilled rotors and ebc green stuff pads, undercoating, and possibly plasti-dipping it or getting a cheap maaco paint job. All in all I think I got a pretty solid deal for $3600. Thing drives just like a tank but has a super smooth ride(ome) and accelerates way way better than i had expected it would.
So, I had a few questions.
1. What weight of oil for the diffs(no lockers except center diff btw), trans, engine. Keep in mind I dont mess around when I buy oil, I buy imo the best synthetic you can so the parameters for viscosity stretch.
2. What should I expect out of the 1fzfe? Any problems? Didn't see to much on them for the 80 series
3. Were online would be a good place to pickup used parts(fenders, doors, hub caps)
4. How could I improve my MPG? Probably a dumb question and wont happen unless I do a trans swap but is there overdrive kits for these?
Thanks for your guys' time
Blade
![1451438_937462476279923_5748399211319622504_n.jpg 1451438_937462476279923_5748399211319622504_n.jpg](https://expeditionportal.com/forum/data/attachments/181/181779-29721baedd7a44b4167fa6d7308c0bc6.jpg)
Blade
