Mercedes 1117A Overland RV (aka The Amstervan)
Sdos
Mercedes 1117A chassis with 2+1registered seats
First registered in 1994
Approximately 371,000 KM (230,000 Miles)
Truck was completely overhauled and converted in 2018 by Twiga Travel of the Netherlands
$350,000 USD
Call or Text Scott @ 813.928.4690
Located In Tampa Bay Area FL.
Mercedes 1117A 4x4 truck chassis
  • Turbo Diesel Engine
    6 Cylinder engine from the OM366 Daimler
    5.959 Liter Turbo Diesel Engine (Fuel Efficient)
    170 HP @ 2100 RPM / 580 Nm @ 1600 RPM
    OM356.947 Engine Baumuster (engine type)
  • Driveline & Transmission
    Wheelbase 4.25 meter (Prof. Extended from 3.64 meter)
    Permanent 4x4
    Mercedes 6 Speed G3-55/6-8,5 Gearbox
    6 Forward gears, 1 Reverse gear
    ZF VG500 Transfer case
    Crawler gear
    Front and Rear Differential lock
    Leaf springs Front & Rear
    Koni Shock Absorbers
    4.7 Ton Front Axle
    9.2 Ton Rear axle (Registered 7.4 Ton
  • Tires
    Pirelli 385/65R22,5 tires
    Custom made 8 lug steel 22,5 inch rims
    2 spare tires including 1 rim (see living unit exterior)
  • 4-point torsion frame
    Front & Rear central bearing
    Central Left & Right torsion bearing
  • Diesel Fuel system
    105 gallon diesel tank
    Fuel tank Bashplate / Protector
    SEPAR Water / Diesel separator
  • 20 liter Diesel tank for 2 Webasto Diesel heaters (See Living Unit)
  • Webasto Air Top + Liquid heater
  • Under chassis boxes
    Left Center – Spare parts & Gear
    Left Rear – Gas bottles
    Right Center – Spare part & Gear
    Right Rear - Spare part & Gear
  • Full Air-Brake system (no hydraulics)
  • Fog lights in front bumper
  • Driver's cab Inside
    ISRI Drivers & Passenger seat both Air-Suspended
    Both seats with Head rests
    2018 Custom upholstery
    3rd centre console seat with seat belts (registered)
    Rear box storage system with 3 hatches
    Custom made Cushions cover the storage system
    Eberspächer Cab heater with timer control (diesel line not connected)
    Longhaul AC system
    Ceiling curtain railing separating rear / front
    Curtains for rear Left / Right windows
    Crawl-Through door passage
  • Drivers cab outside
    Large powder coated Roofrack
    Staircase to Roofrack at Left & Right, Folds outward for easier climb
    2 forward facing LED flood lights
    Rear cab windows (for passengers)
  • Tow hook at the rear side (for towing the truck when stuck, not registered)
  • Rear LED flood lights at Tow Hook height
Living Unit
  • Aluminium Living Unit exterior cage (See page 24 for impression)
  • 60 mm Sandwich panel Walls & Ceiling
  • 57 mm insulation + 2x 1.5 mm GFK walls
  • 60 mm roof panel is walkable, access through stairs at drivers cab & access through roof hatch in master bed room
  • 100 mm Insulated floor
  • Internal steel frame for connection to Sub-Frame
  • Outbound Entrance door 62 cm wide with fly-screen and 3-point locking
  • 4 Outbound Real Glass windows with night blinds & insect screens
  • 2 rear storage hatches
  • Right Storage Hatch 98 x 59 entrance (See Garage Living Unit Interior)
  • Left Storage Hatch 57.5 x 86 cm entrance (square)
  • Cassette Toilet hatch – Mid Right side
  • Outside shower - Mid-Right (left of entrance door)
  • Water filler opening - Front right (to water tanks in sitting corner)
  • Landline socket – Rear right side
  • Roof branch guards Left & Right
  • 3 Solar panels (300 Watt each)
  • GEBO Bathroom roof hatch
  • Outbound Roof Hatch above Sitting corner and in Master bedroom
  • Floating Retractable Staircase (2 quick steps at under chassis box), Does not touch the ground through support rack
    • Wide steps 50 x 20 cm (suitable for dogs
  • 4 Mud-plates mounted at the slanted rear side of the Living Unit
  • 2 spare tires in rear tire rack including 1 steel rim (Mounted to Exterior cage)
  • Manual Hoist pole (Davit Style) stored in Garage
The robust interior is professional made in 2018 with a bright High Quality Bamboo
finish. The interior is in pristine condition with little to no signs of use.
The kitchen has a large working space, the sitting corner can be converted to a
spacious bed.
  • Interior height 195 cm (2.01 in the bathroom shower)
  • Vinyl quality flooring
  • High Quality Bamboo Furniture
  • Truma Saphir Air-Conditioning Unit with remote control
  • Table 85 x 100 cm
    • Table feet can be lowered for bed conversion
    • Table can slide Left / Right for better entrance
    • Bed space 127 x 200 cm when converted
    • 3 storage hatches under Left / Right / Central bench
    • Left bench hatch: water & heating system
    • Central hatch: storage + water tank service hatch
    • Right side hatch: storage + Truma AC system
    • Ventilation hatches in the backside of the benches
  • Left & Right overhead lockers
  • 4 Overhead LED lights
Kitchen
  • Large Kitchen block with stainless steel top – 94 cm height
  • Thetford gas hob with 2 burners, with burner-rings off-road proof.
  • Dometic gas oven
  • 130 liter Webasto compressor fridge + freezer compartment
  • Large sink with hot / cold water mix water tap with retractable head
  • Large storage spaces
  • 3 overhead cabinets
  • 4 large drawers
  • 1 pharmacy drawer
  • 1 clothes closet (same size as pharmacy drawer)
  • 2 AC sockets above kitchen block
  • 1 110 outlet in garage wall
Master bedroom
  • 140 x 200 cm bed space. (queen size)
  • 2 overhead storage cabinets on feet side.
  • 2 LED reading slights at the bottom side
  • 2 large head side storage lockers
  • 1 Outbound Window at feet side (with night blinds & insect screen)
  • 1 Outbound roof hatch with night blinds & insect screen
  • Akwamat 2 natural fibre - under matrass - ventilation
Bathroom
  • Dometic Cassette toilet with electric flush
  • Sink with hot / cold water mix water tamp
  • Thermostatic shower faucet
  • Bathroom storage locker, 2 doors with mirror & separate light
  • Shower floor 75 x 68 cm
  • GEBO bathroom ventilation hatch
Water system
  • 300 Liter Water tank
    • Located under sitting corner floor (frost protected)
    • Manual flush in the floor (storage)
    • Service hatch in sitting bench
  • Jabsco 24 volt membrane pump
  • Pre-filter at suction side
  • 24 liter Webasto boiler electrical / diesel heated
  • Wykomar 3 stage Water filtration system, Fine + Carbon Filtration stage
  • UV purification tube
  • 75 Liter Grey Waste water tank (outside), Frost protected by Liquid Diesel heater
Heating system / Cooling
  • 4 kW Webasto Air Top Evo 40 heater
  • Heater Ring system
  • 5 kW Webasto D5W Liquid heater
    • Heats the water boiler
    • Frost protects the waste water tank
  • 24 liter Hot Water boiler
    • Electrical heated (220 VAC)
    • Diesel Liquid heater
  • 1800-Watt Truma Saphir Air Conditioner with remote control
  • Separate Drivers cab Diesel heater (See cab interior)
Electrical system
  • Battery bank 800 ah @ 25.6 Volt (20.5 KWH)
    • 4 Victron Lithium Phosphate 25.6 V 200 AH Smarth Batteries (installed 2023)
  • Victron energy Centaur Battery charger 24/3000/70 Inverter/charger (110v)
  • Victron Energy MultiPlus
  • 70 Amp Battery charger
  • AC Mains 90 -230 Volt
  • Victron energy MPPT Solar Panel charger 150 / 35
  • 900 Watt Solar Grid (3 panels @ 300 Watt)
  • SAMLEX BS160 battery separator from Alternator / Starter battery
  • Victron Phoenix 3000 Watt (210)
  • Victron energy Orion 24 to 12 Volt - DC-DC inverter
  • Victron BMW-712 Battery Bank capacity monitor
  • Battery bank safety switch
  • Victron Energy Color Control GX Panel with VE Bus
  • Switch panel & Group fuses
  • LED lights with 3 button remote control switches
flipstick
