Military H1 Hummer M1102 Trailer Kansas City
jagular7
Selling a military Hummer HMMWV M1102 light tactical trailer (actually have 2 for sale). Camo green color with full tarp. It weighs under 1500#s empty, can carry 3000#s offroad. The bed is aircraft aluminum and frame is chromoly steel. Suspension is fully independent trailing arm with rubber torsion. There is a drop tailgate and there are rear stabilizers to make loading easier. Tires are 37" Goodyear Wrangler M/T, with double beadlock runflats. The trailer has surge brakes and parking brakes so it can be pulled any truck capable of pulling it with a pintle hook. Lunette height is 29". Since torsion axle is up against frame, this provides 16" of ground clearance!
Great for utility, 4x4, offroad work, heavy hauling, etc.
Lighting is 24V. New bulbs are required for 12V or run your own lights (flat4 setup) since trailer has surge brakes independent of the pull vehicle.
Dimensions
Overall Length: 132 inch
Bed Width: ~80 inches
Bed Length: ~93 inches
Between Wells: ~56 inches
Rail Height: ~20 inches
Trailers are located in Excelsior Springs, MO, just north of Kansas City, MO.
Asking $1450
I can request a paperwork for trailer titling purposes at extra cost ($75), if necessary.
jagular7
Pick the first one yesterday. Its like brand new. Tires, wheels, paint, deck, top. It does have some indication of military use from being in a yard and moved around. But freakin' clean. Couldn't put 2 on a 18' trailer so I'll pull the other home later this week.
This one does have a broken brake line, easily repairable, plus few broken plastic buckle clips to hold top. Didn't have an issue pulling backwards in 40-50 mph gusts.
There is an adjustable tongue stand. Took it off trying to get 2 loaded.
jagular7
Flat towed the second home. No issue. Brakes work fine. This is almost new looking as well. Amazing. Asking $1250 each.
jrose609
Mike,
Have you ever looked into shipping one of these? Ay thoughts? I'm looking for one. I live in Boise, Idaho. Your trailers look pretty nice.
jagular7
No, I haven't. I've haven't shipped big items for a while now. Last big item I shipped was a Pinzgauer box. It went flatbed through Uship from Kansas City to Oregon and that was some 5+ yrs ago. Uship is a contract between you and the contracted service. You can also look at car haulers, personal haulers (rv pullers and the like), and possible trailer mfrs that ship their trailers stacked on each other.
More research on the trailer, I've found the pdf of the TM (353pgs) and mfr's website (schutt industries). The magnetic tow lights wouldn't work under the frame but did on the extended portion for lifting. What I've found, the frame and body are aircraft aluminum alloy for its light weight and high strength.
jacob_lashell
