teotwaki
Excelsior!
I have no connection with these guys. I almost hate to know the price :sombrero:
http://www.silvereaglemfg.com/military/L-WATTS-tactical-trailer.shtml
SPECIFICATIONS
L-WATTS — J8 Extended Deck Platform
(Light Weight Advanced Tactical Trailer System)
Weights
Maximum Vehicle Weight ................3500 lbs (1588 kg)
Curb Weight ........................................1300 lbs (590 kg)
Maximum Payload Capacity ................2200 lbs (998 kg)
Tongue Weight ................................352 lbs (160 kg)
Dimensions
Overall Length ................................139 in (353 cm)
Overall Width ........................................76.6 in (194.6 cm)
Overall Height........................................49 in (125 cm)
Overall Height (w/ high rise canopy) 76 in (193 cm)
Track Width ........................................63.5 in (161 cm)
Drawbar Length ................................95 in (241 cm)
Pintle Height (level) ........................27.6 in (70 cm)
Hub Face Width ................................65.5 in (166 cm)
Cargo bed
Bed Height (unloaded) ........................49 in (125 cm)
Deck Height (unloaded) ................33 in (84 cm)
Inside box width (inside fenders) ........48.1 in (122 cm)
Inside box length ................................88.6 in (225 cm)
Carrying Capabilities ........................2 NATO pallets
1000 mm x 1200 mm
Running Gear
Suspension Type: ................................Fully independent
progressive rate
trailing suspension
Axle ........................................................Tubular Steel
Spring Media ........................................Progressive rate
torselastic rubber
chords
Shock Absorbers ................................Telescopic, direct
acting, one per wheel
Wheels ................................................Jeep 17 in (432 mm),
5 lug x 5.5 inch
(140 mm) BC
Tires ................................................BF Goodrich
T/A LT285/70R17 RBL
Brakes ................................................Drum parking brake
Electrical System ................................12/24 V
Performance
Max Speed (Primary Roads) ................65 mph (405 km/h)
Max Speed (Secondary Roads) ........35 mph (56 km/h)
Max Speed (Off Road) ........................15 mph (24 km/h)
Departure Angle ................................40 degrees
Turning Radius ................................14 ft. (426.7 cm)
Fording ................................................36 in (91 cm)
Ground Clearance ................................15 in (38 cm)
flyer: http://www.silvereaglemfg.com/military/documents/L-WATTS-sheet.pdf
SPECIFICATIONS
Weights
Dimensions
Cargo bed
1000 mm x 1200 mm
Running Gear
progressive rate
trailing suspension
torselastic rubber
chords
5 lug x 5.5 inch
(140 mm) BC
T/A LT285/70R17 RBL
Performance
