Mistubshi car help
MoGas
Central Scrutinizer
I'm working on a 2001 Galant for a girlfriend of my wife's. Here's where I'm at:
Troubleshot it to the fuel pump. There is power to the pump, but no pressure.
I went to Checker for a new pump and it is only the pump motor itself, usually not a problem.
I took the old pump out of the vehicle and found that one of the wires in the harness that is in the tank is actually burnt. I pulled the pump off the assembly and put power to it directly and it is locked up.
I need to find a parts breakdown to see if the little harness in the tank is a replaceable part so I can rebuild the assembly, or, if I need to get a whole new pump from the dealer.
Does anyone know of a Mitsubishi website similar to this Toyota site to look up parts?
Thanks,
Dave
off-roader
Only place you might find that is in the Factory Service Manual from Mitsu. You could also try one of the many Mitsu Auto forums out there. I know there is quite a strong following and someone may have a scan of the right page they can give you. I know this is the case for Mitsu 4x4's.
jesus m anderson
