Chaos
I'm starting a new chapter in my life and I can foresee not using this trailer to it's full potential therefore it is with great regret that I'm going to sell my RTT trailer. As of right now the RTT is NOT included with the trailer nor are the MFCs. As you'll notice from the pictures I chopped off the front 36" of the stock trailer to accommodate a nose box and room for 6 Scepter MFCs (well 4 MFCs and 2 water). I pulled the trailer with my 04 Tacoma without any issues, it pulls wayyy better than my 5x10 utility trailer!! I've had it on the freeway fully loaded with camping gear going 80 mph. If you truly want a turn key solution for an RTT trailer, I will consider including the RTT but I prefer not to. I'm located in the Salt Lake City Valley.
The below is a short list of the details of the trailer, PM me with any questions.
Custom Aluminum Lid with intergrated RTT bars- used 1/8” 5052 (so strong I can stand on lid without
any issues)
Grease-able hinges
De-sta-ca Latches
200 LB lift struts
Water and Dust Proof
Front 36” of trailer replaced with ¼” 6061 Aluminum deck
Custom rack for 6 Scepter MFCs
Weather Guard Aluminum box
Converted Military lights to 12V and 4 pin but can re-wire to 7 pin
Military drop axle
Each wheel has hand brake
Brake lines still intact from Military surge brake.
Military 37” Goodyear MTR (I’m told they’re run flat but haven’t confirmed) have less than 2,500 miles
on them, new when purchased.
Hutchinson Bead-locks
Removed lunette to install AT hitch plate for max coupler
Max coupler – New style
8000 lbs bulldog hand crank leg
Two rear stabilizing bars
Price $4,000.00 Or Best Offer
any issues)
Grease-able hinges
De-sta-ca Latches
200 LB lift struts
Military drop axle
