Hello Everyone, new to participating in the forum here although I've been a longtime reader and appreciator of it.
My question is pertaining to our 3rd gen Montero Limited. We've had it for over ten years, it has almost 230k on it and is still going strong (the only real problem it's had is the ABS unit going out). The problem now is this: we've noticed over time that with people and gear in the back, the rear sits really low. The vehicle has a hitch on the back which we use for a mountain bike rack, and when loaded, the hitch reciever is only about 4 inches off the ground.
We decided therefore to put a 2" lift kit on it (with 33's), and, with the high mileage in mind, decided against a more expensive "doing it right" lift kit (i.e. Dobsons), and just went with lift blocks on top of the springs.
So after all this lead in, here is my question for you all. With tremendous effort and fenagling, I got the struts back in with the blocks installed, but on the rear, they are too long with the blocks in place to get the lower A-arm close enough back into position to jack the A-arm back into place. I used spring compressors to get the front in, but I'm concerned about how much I have to compress the rears to get them in place. Not sure what the load limit is on the compressor I'm using, it doesn't seem to be listed anywhere.
I've included a photo (middle one below) that I hope will show the problem. Also included are photos of the vehicle previous to the lift, and one with it as is now, up on jackstands with the front lift blocks in place. Thanks for any input in advance, much appreciated.
