Montero Alignment in Houston
commostud
Does anyone know were I can take my Montero to get it properly aligned in Houston Texas? I have tried twice and the said they could not align the rear wheels. My passenger rear needs camber adjustement and both wheels need toe adjustment. They said the rear alignment is good for total toe between both rear wheels. But I just want it correct to save wear on new tires. My bushings are good and I bought the spare camber and toe adjustment bolts in case I need them.
Gen 3 I assume? Look for a Frame & Axle shop. They can usually do every alignment. I took my Gen 3 to F&A in my local area, they cussed a lot, but got it done, replaced a couple bushings and camber bolts.
I will look up that kind of shop and give it a go. I am driving 4500 miles from Houston to Anchorage and need it properly aligned. And Yes, it is a 2003 Montero.
  • Like
Reactions: plh
NMontanari
