Toasty
I figured i should post a little info because it's been getting brought up a lot lately. Anyone who knows feel free to add info and links to stuff.
First off anyone looking to regear a Gen 2 Montero with the larger drivetrain (1994-2000) Tom Woods has the driveshaft and flange info on hand so that anyone looking to do this swap can just place an order and get what you need to connect your axles to your NV241 transfer case. These cases come in two ratios 2.72: and 4:1, the first one is the common one and typically cost around $100 while the second one is the Rubicon Rocktrac and will run you around $1000.
You will need:
98+ Jeep Cherokee AW4 tailhousing and pulse gear (Ian Sharpe says you can clearance the AW4 housing for the Montero gear alternatively but i haven't done that yet)
NV241 23 spline short shaft
speedo interface (Dakota Digital makes some nice ones)
New Driveshafts (Tom Woods or a local source or if you're feeling precise DiY)
*if going the route of using the Jeep pulse gear you will need to counter bore the back side of the gear to match the height of the Montero pulse gear (i'll post up a pic a little later)
Modify your transmission cross member, the new tailhousing accepts the Jeep style mount so there are a lot of options and simple solutions. The Montero cross member is flippable in case you need to offset it's location depending on what you do
Here's some usefull threads
ES 97 Sport's swap
NathanC's swap
You will need:
ES 97 Sport's swap
NathanC's swap
