more storage options
KSJeep
Koplin does make and sell them here in the US. Most any ATV dealer or the Big Box sporting goods stores that sell ATV Acc, should have them (Gander Mountain, Bass Pro, etc).
apsilon
I saw photos of these on a rig some time in the last week. I thought it was here but could've been another forum. Looks like a good idea.
FJLED
Don't go with the Koplin packs that are sold in the local stores. If you search around online you will see a number of reviews that note they tend to leak.
Rotopax used to make Koplin's product line years back until Koplin decided to switch the design. However, along with Koplin's design change came the leakage issues that have been noted on many of the atv forums.
Rotopax on the other hand have great reviews by all the ATV guys that use these. I ended up purchasing 4 of the gas fuel packs from Rotopax. The fit perfectly on top of my GOBI roof rack and are low profile enough that they don't cause any wind resistance.
I filled them up when I left Houston and drove all the way to Cloudcroft, NM with them. I had forgot to leave some space in the fuel packs for expansion due to elevation and being out in the sun. Needless to say when we were on top of one of the mountains I hoped up to take a look at them and they expanded more than I could believe. I thought for sure that there had to be leaks, but upon closer inspection there weren't any issues at all.
Get two thumbs up in my book and are a nice alternative to jerry cans.
Ric
great heads-up, do you happen to have any pix ?
FJLED
Copied my review for the FJCForums. For the full thread http://www.fjcruiserforums.com/forums/4x4-off-road-tech/93008-rotopax-fuel-pack-jerry-can.html
UPDATE 2 - Review continuation
Well first let me say that I am more than happy with the money I have spent on this product. After my recent trip to NM for TOTH I am looking to purchase a set of the water packs as well from Rotopax...thats how impressed i was with their product.
I left from Houston, TX last Thursday night and filled with the Rotopax up at the local Costco as we headed out I-10. We were driving through the night and riding on trails as soon as we arrived Friday, so I figured it would be easier to fill them as we left Houston. Needless to say the Rotopax held up flawlessly on the 750 mile drive to Weed, NM. The only issue I had was the knocking of the straps which I hadn't tied off once fully tightened, but this was corrected by pulling off at an exit outside of Houston and tieing off the excess portion of the strap. Anyways we arrived in NM and I was happy to see that there was no sign of leaks on the fuel packs or the roof after the 12 hour drive!
Needless to say I didn't think this was a tough enough test yet for the rotorpax. Instead I decided to leave them on the roof for the entire duration of our trail runs rather than remove a few and store them at the campsite. I figured being in the sun all day and the afternoon heat would really test the fuel packs out. However, I actually tested them even more than I expected due to the fact that I filled the fuel packs in Houston which is basically at sea level and then drove to about 9000ft. I hadn't left much extra room in the pack for expansion due to heat let alone the altitude change!
Needless to say during the trail run on Friday I finally took the time to inspect the packs when we were on top of hanglider hill (name should give an impression on the elevation). The packs had expanded to a considerably and it looked as if the ratchet straps were a size 32 belt trying to fit around a size 40 waist individual. The straps were definitely putting a good amount of pressure ("squeeze") on the packs. At this point I was quite concerned about the packs leaking, but when I inspected further there were no signs of leaks. I was honestly quite surprised since the expansion due to altitude and heat was quite considerable.
Here are a few pictures of how I had them mounted on the roof.
jacob_lashell
