Mounting a Power Tank
I'm hoping Stan will chime in on this, but I'm wondering if there is enough structural integrity on a Four Wheel camper to mount my Power Tank to the back wall. I've attached a picture of the proposed area.
Thanks
rayct77
I'm guessing if you can mount a 5 gallon tank of gas you should be able to mount that. Seems like it would be fine.
I can drill through. There's a little room between the wall and the fridge. I'll probably drill through the studs and put some metal plate behind as well. Thanks
craig333
I'd consider using the jack bracket to support at least some of the weight like I did here on my can mount. No holes drilled through the side of the camper.
Power tank is a brand of c02 cylinders setup for Offroad use. I run air tools and air up tires with mine. I don't use the powertank brand tho. Way too much money. I have 140 bucks into mine. Power tank wants 500 ish
iStan814
